Vray DR and texture problem, help pls
  • Vray DR and texture problem, help pls
    im rendering a scene with DR, slaves buckets render without textures BUT i check maps and they all pass thru network path. ANyone has solution to this?
    Ryan
    if you find a bug...kill it.
    Well those machines are simply not seeing those maps.
    What paths are you using mapped drivers or UNC
    Example:
    g:/textures/map.jpg
    //server/textures/map.jpg
    Try copying the maps local on each machine.. that will work.
      im using //server/textures/map.jpg.
      i tried rendering using the slave machine not DR and it renders all maps just fine. but not when using DR
        i had fixed the problem now, i just transfered my slave to another network port.
          Ah cool.. easy fix
