rotating vray hdri map
  • rotating vray hdri map
    gimbal lock? That's my first impression.
    I've got a light that starts at the top. I want to rotate it down a bit, maybe at 50 degrees or so, then rotate it around the scene from there.
    Does anyone have another way of doing that? I really like the vray hdri map more than the max bitmap method. It's nice to be able to change the values after the map is imported.
    If I'm correct in how this works then i'd really like a button to make it so we can manually choose which rotation to do first.
      andrew, you can use the HDRI in a VRaydomelight and rotate it any way you want
      Chris Jackson
      Shiftmedia
      www.shiftmedia.sydney
