vray displace problem
  • vray displace problem
    hi all,
    how can I use vraydisplacment on single mat id on mesh wich have multiple mat id on?
    thx.
    http://www.3dvision.co.il/
    You can do it this way:
    Assign a multi/sub material to the mesh, and for the material that correponds to the desired material id, set a displacement map.
    Apply a VRayDisplacementMod modifier on the mesh, use 3d displacement and tick the "Use object mtl" and "Keep continuity" options.
      i will check this, thanks vlado
