I'm rendering product, which has top side from glossy transparent plastic. Below it, there is a circular plate with grooves, also from same material. Below plate, there is another plate with eight blue LED diodes, which illuminate it from inside. LEDs are small Vray spherical light with NoDecay enabled. I tried with decayed lights, but did not illuminate interior enough without very high multipliers, but lights then turn white.
Scene is illuminated with three Vray plane lights. I had to increase subdivs to 80 to eliminate noise.
Transparent material is standard Vray material with glossy refractions (0.92), 20 subdivs and interpolation on. Max depth is 20.
It is part of greater scene, which consist also from parts, made of regular plastic, but all scene is rendered fast except transparent stand on picture below.
Render times are ridiculous, for 960*1280 picture more than 40 hours. Can anyone help me to cut render times without sacrificing quality.
Below is picture of problematic stand and render setting. Picture was NOT made with setting below, it si a low quality preview just to see, how it looks, because higher quality picture is still rendering. Second picture are render settings for picture without noise, which is currently still rendering. Quality is good so far, but renders times are not.
I'm quite new with Vray, so any suggestions are very welcome. Thanks.
