MAX 9 installation problem
  • MAX 9 installation problem
    Hello,
    I'm trying to stup vray 1.5 RC3 for 3dsmax 9. The setup is all fine but when I load 3dsmax9 I have lots of erros messages of this type "Unable to load ... vraydomecamera.dlo> Error code 126 : Can't find module "
    Which module does this message speak about? I've tried to add the "Chaos group program files" folder to the Windows path but nothing does.
    Any help would be appreciated.
    Thanks.
    Stephane.
    The problem is in your plugin.ini make sure the vray plugins load after the regular "plugins" folder by setting their order correctly in the ini
    Code:
    Additional MAX plug-ins=D:\3dsMax9\plugins
    V-Ray additional plug-ins=D:\3dsMax9\plugins\vrayplugins
    Eric Boer
    Dev
      You are right. This is the solution.
      Thanks a lot for the quick answer.
      S.
