v-ray camera, sun and sky: missing dll
  • v-ray camera, sun and sky: missing dll
    Hi all,
    I've been having this problem ever since I got v-ray and never been able to fix it. When I render a scene locally on my workstation everyting renders fine but when I use DR, I always get either a black bucket or the v-ray window can't find the dll on the render node. I have checked and the dlls are all there in the plugins folder on the render node. When I render v-ray lights or anything else, DR works fine.
    I've been starting to use these (sun/sky/cam) alot since they are so amazingly easy to work with but then I'm able to render on only my workstation. This is a big problem because it takes longer to render my scenes using only one computer.
    I'm using a Boxx workstation (2x dual opteron 285) and one render node (Boxx also) with XP pro, max8SP3 and v-ray1.5-RC3. We are looking to buy more nodes from them and I want to fix this issue before we get more machines.
    If you need more info or more specs just let me know.
    Check the plugins.ini on the slave make sure the max plugins are loading before the vray plugins.
    Eric Boer
    Dev
