Dark Corners in Animation
  • Dark Corners in Animation
    hi folks
    we get some problems while rendering frames out of an animation.
    it's all about camera flythroughs, no objects moving, so we decided to
    use precalculated LCs and IMs.
    take a look at the pic. you'll notice dark corners (marked).
    the LC subdivs are set to 6000 with a size of 20cm (world scale) for a 600 frames animation.
    is there a solution to avoid those dark corners?
    thanks in advance.
    greez
    ale
    ____________________________
    www.indivizuals.ch
    turn off detail enhancement in irmap settings...i guess!
    Nuno de Castro
    www.ene-digital.com
    nuno@ene-digital.com
    00351 917593145
      =) i forgot to tell, we're still on Max 7.5 with Vray 1.47.3. so no DE there.
      but thanks for the quick reply.
      www.indivizuals.ch
        There is a "blur GI" parameter in the irradiance map settings... it should be 0.0, otherwise you might get things like these.
        ene.xis: detail enhancement will not produce dark corners like these. It is not a simple AO pass, instead it will do a more accurate GI calculation.
          ...absolutelly right vlado! silly me...or sleepy
          Nuno de Castro
          www.ene-digital.com
          00351 917593145
            thanks guys.
            vlado the 'Blur GI'-thing did the trick.
            thanks again.
            ale
            www.indivizuals.ch
