Xref Object not displaying with Distributed Rendering
  • Xref Object not displaying with Distributed Rendering
    Any help is appreciated.
    Running main MAX scene, all Xref Objects and Materials from a server. All paths are identical on every machine I'm using for Distributed rendering.
    MAX 9.0 with Vray 1.5
    All Xref Objects and Xref Scenes don't render. I was able to render Xref Objects located locally on the host HD, but thats useless if other machines can't see the files.
    I can't get Backburner working with MAX 9.0 would that have something to do with it?
    Thank you in advance.
    Did you use UNC Paths?
    Dieter
    visit my developer blog
      Originally posted by dimo
      Dieter
      No, but the drive Letters match.
        what version of vray are you using?
        Chris Jackson
        Shiftmedia
        www.shiftmedia.sydney
          I remember there was a problem with this in 3dsmax 8, which we fixed, but if something has changed in 3dsmax 9, I suppose this may be a problem again. I will try to reproduce this here, but if you have a simple scene that you can send me to vlado@chaosgroup.com, it will be very helpful.
            I cant send the scene I'm using I'm afraid. Its clasified.
            Also, I dont believe it is a network problem, I can render a Vray scene using Backburner, so I know it each computer can see the Xref Objects on the Network.
            I'm guessing it's a Vray Bug.
