Does anybody else get crashes when you try to apply a Vray color map? I do!
Vray Color - crash
Tags: None
This happens only in some intermediate versions of RC4; if you wish, you can email me at vlado@chaosgroup.com; in general, for any problems with unofficial builds it's better to email me directly, as few people on the forum will be able to help you.
VladoI only act like I know everything, Rogers.
But I am using RC3. Do you know of any issues with that version?
Thanks.
Ahh, I don't think it is just a Vray Color problem. Now in Max 9 I get lots of crashes when I try to do sub-maps like falloff or Colour Correct. It's really bad. I haven't even successfully used the CC plugin yet, which really sucks. It crashes every time.
sounds like that problem i was having where i couldn't drag a 'none' map without it crashing, which also seemed to fix itself... although I've moved on from that particular scene now that was causing the problem.
although vlado said he had found the cause.WerT
www.dvstudios.com.au
Originally posted by werticussounds like that problem i was having where i couldn't drag a 'none' map without it crashing, which also seemed to fix itself... although I've moved on from that particular scene now that was causing the problem.
Originally posted by MoonDoggieyou can fix this but unenabling the bitmap in the viewport then clearing the map.
-Colin
Thanks so much!
Edit: Oh, and thanks Vlado too! I didn't read your post above until just now.
you could always write a maxscript to turn them all off for you to make sure you don't accidently do it like I always seem to do:
Code:for o in objects do ( try ( showTextureMap o.material o.material.diffuseMap off ) catch () )
Hope this helps as well.Colin Senner
MoonDoggie - really thanks for this, i tried to get a mate to write me a script to do just this years ago - many thanks i'll definitely be using this.
timmatron - when you say ColourCorrect, do you mean with the 3rd party ColourCorrect plugin? I noticed you said for Max 9? Is it available now? This was my most used and useful plugin for Max 8, and i hate using Max 9 for the simple reason i don't have this.
If it's available could you let me know where to get it from again? Many Thanks
Yeah it's out for Max 9 although only 32 bit unfortunately.
http://www.cuneytozdas.com/software/.../#ColorCorrect
