I always thought that alpha-compositing is only used if you want to mask out an existing background - in this case, the alpha is used to cut the object out of the background before adding the rgb object itself. However, if the object is already cut out, you just need to add the rgb object, without masking anything. In the the exampe posted by seraph, you will get a perfectly correct result if you simply add the rgb images, ignoring the alpha (if you do need a final alpha too, it is just the sum of the alpha of the two images). Of course, you need to render the different layers to a black background for the adding to work properly.
