Door woes
  • Door woes
    VRayers,
    Just wanted some advice for fixing this small problem I'm having
    Here is the image
    Some info:
    - The door is 80 polygons (160 tris), welded and smoothing grouped well
    - The final render is low hd 1280x720
    I realize the imap settings are a bit low, but even then, shouldn't be producing such poor results, anyone have some advice for my strange doorframe problems?
    -Colin
    Colin Senner
    Boost up your irrmap and switch the lightcache to per frame instead of flythrough
      You also need more subdivs for the light cache, 250 is not good for anything. Try at least 1000.
        done and done, I'll let you know how it goes in a few minutes.
        -Colin
        Colin Senner
          Colin, what version of vray are you using?
          Chris Jackson
          Shiftmedia
          www.shiftmedia.sydney
            colin, im just asking as the UI has a few different things to the max UI
            Chris Jackson
            Shiftmedia
              Hey is that what the new build is going to look like? and why is there filter size and interpolate with the nearest filter parameter?....man i cant wait.
                Yeah, and also what is the P and the G for next to environment map slots. How come I don't have those?
                "Why can't I build a dirigible with my mind?"
                  tsk tsk colin. I think he posted screenshots of the vray ui from inside rpmanager?
                    Sorry to get your hopes up,
                    Currently using RC3, those Screengrabs were as percy said from RPManager, don't get excited, the G and P buttons only [G]rab and [P]ut the currently selected material in the material editor in the slot since scripts don't support dragging and dropping like that.
                    I'll be re-rendering these today with the suggestions implemented.
                    -Colin
                    Colin Senner
