VRImg saving Dialog error
  • VRImg saving Dialog error
    Hi Guys,
    Something Ive not found mentioned before doing a search through the forum.
    I set up a scene and click the browse to save the output as a VRImg file. Send it off over the network and it works fine. I then edit the file save name in the bar stating the save location, ie not by pressing browse and changing the name there. Send off the file and get errors all the time .
    It seems theres a problem with editting the files save name in this bar, and has to be done through the browse dialog.
    Hope this helps someone! And can be fixed for future releases.
    Thanks
    Mark
    Hello Mark,
    Which edit box / browse button do you have in mind?
      Hi Vlado,
      Its the V-Ray raw image file section of the V-Ray:: Frame Buffer window, and the text field where the location of the saving file gets put in.
      Thanks
        I guess he means the one in the render dialog, Vlado.
        I'm not sure, though, it's only vray-related, but it has to do with how the max sdk handles it, in fact any max path dialog is different: it's in the form of a butto which pops up a standard file save dialog, rather than a straightforward text edit box.
        Lele
          I see; well, directly entering the .vrimg file has always worked fine for me, but perhaps there is something special about the path name or it was not entered correctly.
