Unwrap UVW
  • Unwrap UVW
    Hello all,
    this is my first attempt to use Unwrap UVW.
    In the viewport looks fine, but when I render I loose some mapping.
    Any suggestion?
    Regards
    Srdjan
    check to make sure you dont have some overlapping faces/duplicate faces.
      Hello Percy,
      thanks for the reply.
      I don't have any of those, all are snapped nicely
      Regards
      Srdjan
        so if you put a simple uvw map on the roof it renders 'okay'?
          Hello Percy,
          I tryed to do that already, and it did not render correctly. If I render with scanline renderer rendered ok.
          What I did now I Unwraped again using instead Unfold Mapping, I used Flatten mapping, and worked just fine. By this being my first UVW Unwrep looks like that was the major issue. I even made Displacement, which for some reason doesnt work correctly, but I will still work on this.
          Percy, thanks a lot for your ideas and troubleshoot
          Regards
          Srdjan
            Hello Srdjan,
            If you think this might be a problem with V-Ray, please send your scene to vlado@chaosgroup.com so that we can correct it.
              Hello Vlado,
              thanks for kind concern I think problem was with my UVW Unwrap. I still have to check, to make sure, where I made mistake.
              Regards
              Srdjan
                Originally posted by percydaman
                check to make sure you don't have some overlapping faces/duplicate faces.
                Hello all,
                besides being "careful" with creating roof model (and being so confident about it), somehow I made duplicate model of the roof, on top of one another my apologies to percydaman and Vlado. At least I learned how to recognize duplicated model now and what can I say, Vray rocks!
                Regards
                Srdjan
                  there is a simple way i did the roofs in ......
                  http://www.elfpro3d.com/Liz/finalt2.jpg
                  all the ones facing easy west i selected and detached then applied a uvw mapping modifyer to it. the ones north south i added a uvw modifier to it too and chose the aquire option and used absolute then rotated the gizmo 90 degrees. each of these had on a displacement modifyer which was instanced. i used 2d displacement and even though there was a seam created i didnt care because i had a row of tiles comming down that edge. if you want to not have those edges then you need to use 3d displacement is its just as easy. once the mapping on either object is setup then colapse them down to editable polys and attach them to eachother. this makes it back to being 1 object and when you apply the displacement you can choose 3d displacement to make sure that keep continuity is on
                    As long all of your roofs are at 90deg to each other an even easier way is to just use the box map . It has a little less variety to it but it's a hell of a lot easier. Normally it wouldn't map correctly to the angled roof faces though. To get it to work correctly just set the height of the box map several time larger than necessary (x3 or x4) and then increase the 'V' multiplier in the material map by the same. Tweak the 'v' multiplier until the size of the bitmap is correct for the angled surface. BTW, this works great for linked DWG files where detaching the surfaces is not possible.
                      box map isnt good. sometimes a side mapped area might be at the wrong angle. you get way more accuracy with what i do
                        The technique you describe isn't any more accurate than using a box map as I describe, it does however give you a little more control if necessary for roofs that have different slopes or are not at right angles to eachother. I used to map roofs just the way you descibe until I discovered this little trick and it's saved me a lot of headaches with roofs. If I have an odd slope or angle I just tweak those pieces with a new box map.
                          Da_elf,
                          I like your roof. I tryed your material, and all I can say it is so nice and neet!
                          There 2 questions, how did you make roof thickness by the eaves, end of the roof? and another one is main surface of the roof is so nice, I couldn't figger out how did you make hip of the roof? I tried to put extra strip (plane) but it intersect, and clash with main plane
                          Regards
                          Srdjan
