Problem with VRayProperties and Maxscript
  • Problem with VRayProperties and Maxscript
    I have a script that needs to copy properties from one obj to another. The problem is that I cannot get the userproperties from an object that has been newly created without first opening the VRay Object Properties dialog for that object. To see what I mean execute this after creating an object.
    Code:
    getUserProp $ "VRay_GI_VisibleToGI"
    I get undefined. Any help is appreciated. Thanks.
    the propbuffer is indeed empty.
    running
    Code:
    doVRayObjectProperties
    opens the vray props dialog.
    What that does is to add to the object user props this:
    Code:
    VRay_MoBlur_GeomSamples = 2
    VRay_GI_Generate = True
    VRay_GI_Receive = True
    VRay_GI_Multipier = 1.000000
    VRay_GI_GenerateMultipier = 1.000000
    VRay_Caustics_Generate = True
    VRay_Caustics_Receive = True
    VRay_Caustics_Multipier = 1.000000
    VRay_MoBlur_DefaultGeomSamples = True
    VRay_Matte_Enable = False
    VRay_Matte_Alpha = 1.000000
    VRay_Matte_Shadows = False
    VRay_Matte_ShadowAlpha = False
    VRay_Matte_ShadowColor = [0,0,0]
    VRay_Matte_ShadowBrightness = 1.000000
    VRay_Matte_ReflectionAmount = 1.000000
    VRay_Matte_RefractionAmount = 1.000000
    VRay_Matte_GIAmount = 1.000000
    VRay_Matte_GI_OtherMattes = True
    VRay_GI_SurfaceID = 0
    VRay_GI_VisibleToGI = True
    VRay_GI_VisibleToReflections = True
    VRay_GI_VisibleToRefractions = True
    So a workaround is to first loop through any object which has no VRay user prop, add these as the default, and move on from there.
    EDIT: to expand :
    Code:
     if ( findstring (getUserPropBuffer $ ) "VRay" )== undefined do (
    setUSerPropBuffer $ "VRay_MoBlur_GeomSamples = 2
    Lele
      Thanks Lele. I think that will do the trick. One note however, when you have a return in a string, you don't need a space (at least it is so in R9). In case others need this at some point, your script has spaces at the end of each line and with the return, the space gets evaluated as part of the assignment, making the assingment "true " rather than simply true.
      Anyway, thanks again.
        this thread might also be of interest for you
        http://www.chaosgroup.com/forum/phpB...ic.php?t=19220
        regards,
        michael
        This signature is only a temporary solution
          regards,
          michael
          Thanks. I saw that one and it doesn't fix my problem.
