vray cameras???
  • vray cameras???
    Guys (n ladies!!)
    I've never really used vray camera's and normally just use viz cameras. However, I've started using them and just wondered what the benefits are over normal viz/max cameras. Also, when I render out a view using a vray camera, it renders out completely black????? if i use the same model and lighting settings using the normal viz cameras i get the rendered out view as you would expect. Any ideas why im getting a black output using the vray cam???? most confusing.....
    cheers
    vray cameras use real world exposures so you can't light the way you have previously. Start jacking up those light multipliers and play with your exposure settings.
      Ah.....do you have any values that work for you.....its an exterior shot im creating...bright sunny day.....about 11am.....pretty cloudless sky
        vray sun+vray sky, maybey?
        Nuno de Castro
        www.ene-digital.com
        nuno@ene-digital.com
        00351 917593145
          Yeh, tried that and its like a nuclear bomb has went off..very very very bright.......washes out the entire scene
            with the vray camera?
            just try to expose ur camera correctly then!
            Lele s script pack has some gr8 tools to do so!
            Nuno de Castro
            www.ene-digital.com
            00351 917593145
              Do a search on the forum, man.
              Tutorials, scripts, discussions, the lot.
              Just up for grabs.
              Lele
              emanuele.lecchi@chaos.com
              Disclaimer:
                there he is!
                Nuno de Castro
                www.ene-digital.com
                00351 917593145
                  Just up for grabs.
                  Heh....I'll take alook...
                  cheers guys
                    Camera
                    I actually read several book on photography and talked to a couple photographers... then after month's of studying I through it all out the door and realized each scene is different and I need to start with a base point and tweak accordantly.
                    For exteriors I use an f-8, shutter speed of 30 and a ISO of 100. I usually place a white box in my scene that will receive direct light and tweak my shutter speed until I get a rgb of 255,255,255 and a float point of 1,1,1 on that box... this gets me pretty close.
                    Having said this, all my materials are darkened first setting the output rgb level to .255.
                    Bobby Parker
                    www.bobby-parker.com
                    e-mail: info@bobby-parker.com
                    phone: 2188206812
                    My current hardware setup:
                    • Ryzen 9 5900x CPU
                    • 128gb Vengeance RGB Pro RAM
                    • NVIDIA GeForce RTX 4090 X2
                    • ​Windows 11 Pro
                      Re: Camera
                      Bobby- for a sunny day exterior those settings (in a real camera) would be far too slow and would produce a white image.
                      With my exteriors my shutter speed is usually around 1000 - 1250 with an ISO of 100 and F8.
                      Chris Jackson
                      Shiftmedia
                      www.shiftmedia.sydney
                        Camera
                        That is why I stopped trying to use real world settings. These settings constantly world for me.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          sounds like you might be doing something wrong if real world settings arent working
                          Chris Jackson
                          Shiftmedia
                            I second what sparky says, there myst be something wrong....
                            look at this thread
                            http://www.chaosgroup.com/forum/phpB...ic.php?t=20003
                            these are real world exposure settings
                            Hope that helps
                            Ingo
                            • #15
                              oops...i meant jacksc02 lol
