omni lights behind vray transparent mat
  • omni lights behind vray transparent mat
    I have omni lights behind a transparent vray mat.
    the refraction glossiness is set to 0.8, so its like frosted glass
    problem is I get white dots on the material in the exact position where the omni lights are behind.
    caustics ar of, tried with caustics, same problem
    so I get @0verbright or invalid colour on the material.
    its like the material makes the lightsources ( omni lights ) behind visible
    any ideas ?
    thank you
    show an image? I wouldn't necessarily recommend using point lights in this manner. Better off using a physical light object like a vraylight.
      Thanks percydaman,
      changed to vraylights and it works fine
