Image noise level
  • Image noise level
    Hello guys,
    i cant get rid of the noise in my scene, especially on the glossy objects and am starting to get furious as have no other option that i know i could change to get rid of it...
    ive got all the material refl/refra subds on 30 samples
    using rQMC image sampler at 1/6
    first bounce IRRAD 50/30 DE on
    second bounce LC 1500/0.02
    rQMC sampler at 0.001 noise tres, subd 30, else default
    scene lit by sun at 8 subd
    have tried to use fixed image sampler at 4 subd.....still makes the noise...this is all weird as it has not happened to me in a long time the noisiness
    here is an example
    i normally in my workflow set all the mats on 24 subds straight away but this time ive set them to 8 first and then used vray automator to set them to 24 all at once...could that be the problem?
    COS I REALLY DONT KNOW WHATS THE PROBLEM...ive got the settings pretty hight already!!!
    can anyone please help?
    thank you very much
    martin
    teabag studios
    www.teabagstudios.com
    it it strange as most of my scenes in recent time r noiseless, so i really dont know what ive done wrong this time....
    teabag studios
      try adaptive sub div image sampler instead of QMC
      otherwise you can also use the image quality multiplier to the right of noise threshold - which will kill render times but probably fix it.
      maybe more LC samples for the second bounce?
      WerT
      www.dvstudios.com.au
        trying LC subdivs at 2000 now with all the mats back at 8, using universal settings with rQMC at 24
        teabag studios
          one thing is strange though...the darker object (by material) the more noise it produces......look at the sinks....they r perfect when we consider noise....and then look at the floor ....
          teabag studios
            I doubt changing LC will make any difference. Does look like that sort of problem to me.
            Does seem really weird. So the only light is the vraysun... try upping that to 20 as well. Doubt that will help as it doesnt seems like it will but cant hurt.
              nope.....neither helps.....(((( any idea what can it be? could it be the vray automator?
              teabag studios
                Maybe. Would suprise me tho.
                You can always switch back to scanline then back to vray to reset all the settings.
                I think its just so dark that the sampler is having a hard time.
                Put a basic grey vray mat on everything and see if the noise still exists.
                Failing that try putting a big low MP vray light in behind the camera and see if that helps lower the noise... im curious.
                  yeah thats what i could cause the problem...the lack of light in the scene...as there r probably not enough samples to go through....will try what u said....thanks
                  teabag studios
                    just had one cam view where there is enought light...and the noise is still there....grrrrrrrrrrrrrrrrrrrrrr...
                    ...gotta go to dentists now ouch....at least i will have some time to think about the problem while he drills in my mouth ))))))))
                    sending u pm daforce
                    teabag studios
                      Hmm weird.
                      Ok looking it over now.
                      Good luck with the teeth
                        thanks a lot.....
                        btw....i will need the luck for sure ....oh how i hate dentists
                        teabag studios
                          Dont we all mate.... dont we all.
                            a friend of mine said it might be caused by LWF, lack of lighting in combination with glossy reflections....he suggested AA at 6/15, but than it would not be animatable....
                            teabag studios
                              Just looking at your scene now.
                              Its kinda odd.. from the camera view it uses up say 500mb ram and 800mb VM if i go to top view and zoom out it goes up to over 2GB and starts paging to disk as I only have 2GB ram.
                              I think its to do with alot of unnecessarilly large textures or poorly compressed ones at that.
                              But im sure thats not causing the noise. Looking in that now... might just eat dinner first
                              (note to self, dont go to top view and zoom out... eeek.. my ram!!!)
