Unhandeled Exception in VIZ 2008
  • Unhandeled Exception in VIZ 2008
    I have downloaded and installed VRay 1.50.00 Max 9 x86 to Viz 2008. I am getting an unhandled exception error that is crashing Viz at startup. I uninstalled VRay and it started up fine, re-installed VRay and get the same error.
    Ben Steinert
    pb2ae.com
    Here I'm running viz 2008 + vray x86 + wibu x64 + dongle with out any error ... at the moment
    Alessandro
      try it again, beestee - sounds like you and I have a startup file that's already prepped for vray, right? I got this the first time I loaded up VIZ08, but it didn't happen the second time, and that time I was asked if I wanted to upgrade my sun/sky/cam to the new model. The other option is to rename your vizstart.max file.
      Right now, I can't get VRay to see my dongle license - any clues?
      ME
      Matt English
      Harper Perkins Architects / base2studios
      VizDepot.com Moderator
      AArch2008/VIZ2008/VRay ONE POINT (WHOOHOO) FIVE!!!
        My VizStart is prepped for VRay...I will save a new one without and try again. Thanks!
        Ben Steinert
        pb2ae.com
          Okay, it is working...somewhat. I am still having trouble opening old files that have pre-existing VRay settings.
          Ben Steinert
          pb2ae.com
            every now and then, I'll get an old file that'll bail on me when I try and open it. Sometimes reopening it works, but other times, I have to merge it into a new file. dunno why this happens - vlado?
            Matt English
              Yes! Merge...I knew we had a workaround for this before. Thanks again!
              Ben Steinert
              pb2ae.com
                no problem! ugh - the hoops we lowly viz users have to go through!
                Matt English
                  Is DR still working through the same methods that are outlined in the tutorial on Vizdepot? I'm getting ready to jump into it once again, now that backburner slaves can host the DR and add slaves "on the fly."
                  We have an IT guy that knows quite a bit about services and scripting, and he seems to think that with these new features it will be plausable to have completely dynamic processor usage on our render farm!
                  Ben Steinert
                  pb2ae.com
                    I would assume so, but I've been known to be made an ass out of many a time. When I get a second, I'll force my wife off her machine and try it here at home. If there are any changes, I'll post them as an addendum to my tutorial at the Depot.
                    ME
                    Matt English
                      quick (dumb) question: where should i find vizstart.max?
                      when the going gets weird, the weird turn pro - hunter s. thompson
                        found it.
                        didn't realise you had to create it yourself! spent about 15 mins searching my computer for vizstart.exe
                        1. Launch Autodesk VIZ and click File > Reset.
                        2. Configure the scene the way you would like to have the program start up. This can include:
                        Viewport configuration settings
                        Unit configuration settings
                        Default geometry
                        Any option or setting saved in the scene
                        3. Save this scene to the following path : <Viz Install Location>\Scene
                        When you restart VIZ, this scene will be used as a template for any new scenes.
