License not working woth VRay Final
  • License not working woth VRay Final
    Can not get license to work with Vray Final. Here are the steps I have done so far.
    (1) Installed VRay 1.50 for max8.
    (2) Installed dongle driver.
    (3) Launch VRay license server
    (4) Checked status of license server (http://localhost:30304/getstatus)
    (5) Statred Max7 software.
    (6) Loaded scene (previously rendered with 1.5C3.
    (7) Open render dialog, confirmed license file setting is "C:\Program Files\Common Files\ChaosGroup\vrlclient.xml
    ( Edited license server information. Confirmed license server is "localhost" and connection port is "30304"
    (9) Attemp to render.
    At this point, the render fails because I can't obtain a license. Any idea what is wrong. I believe I have done all that I'm suppose to do.
    Note: when I check the license status, this is the response I get.
    License type Total Engaged Free
    Render licenses 0 0 0
    Interface licenses 0 0 0
    Network licenses 0 0 0
    DR licenses 0 0 0
    V-Ray licenses list GUI RENDER DR NET
    Sessions list GUI RENDER NET DR Last access
    Default access: DENY
    Explicit allow
    Explicit deny
    Do I need to have the WIBU-Key re-authorized to make it work?
    Thanks in advance for any help provided.
    Ayoola[/b]
    Re: License not working woth VRay Final
    I did....right-click or whatever on the WIBU icon by the clock (lower-right) and tell it to rescan for boxes. It should find your USB key, then start max.
    HTH,
    ME
    Matt English
    Harper Perkins Architects / base2studios
    VizDepot.com Moderator
    AArch2008/VIZ2008/VRay ONE POINT (WHOOHOO) FIVE!!!
      Which V-Ray version do you have (advanced, educational, NFR)?
        I have the educational version.
        Harperperkins
        I have done exacly that several times and still get the same failure.
        Thanks,
        Ayoola
          Ok; in that case I guess that the license on the dongle mismatches the educational version that you have downloaded; this can be easily corrected though - please send me an email to vlado@chaosgroup.com and we'll work this out.
            An email was sent to you regarding the problem obtaining a license when using the 1.50 Final education version and possible mismatch with the dongle.
            Thanks
            Ayoola
              I am having similar problems but with the commercial version. The wibu key is found by the server, but V-Ray does not see it.
                If you have had the dongle running for the RC's you will need to replace the vrlservice with the one that comes with 1.50.00
                Eric Boer
                Dev
                  thanks you answered my problem
                    but it usually asks you to stop running vrlservice when you goto install it. so normally it should be replaced
                      Yeah, special case for those of us that run the dongle on a separate license server.
                      Eric Boer
                      Dev
