glass/alpha problems in vrayfinal
  • glass/alpha problems in vrayfinal
    just got that odd problem where you apply a glass material and the alpha renders out solid. Has this been covered before and is there a workaround?
    alpha renders out normally with standard materials though.
    suggestions?
    Im not sure I understand. Glass material typically has a refraction. Refraction will have no alpha. For this the refraction filter must be rendered (gbuffer pass).
    Otherwise transparency/opacity will be included into alpha.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      check affect alpha in your vray material settings.
