Displacement and Dynamic memory?
  • Displacement and Dynamic memory?
    Hi all,
    I set dynamic memory as low as 200megs, but my displacement grass still crashes vray...
    Turning displacement off for that material solves the crashes.
    Is dynamic memory management not affecting displacement?
    I thought dynamic mem would also work with displacement micro-triangles...
    vray r4, MAX 9 32
    thank you
    regards
    gio
    Gio!
    What are your displacement settings?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      Well, I actually left them to default...
      thanks
      gio
        are you displacing an autocad mesh?
        Chris Jackson
        Shiftmedia
          Can you show us the wire, please
          nikki Candelero
          .:: FREE Your MINDs, LIVE Your IDEAS ::.
            No Autocad, but revit mesh (DWG).
            Now that I think of it, the meshes I am displacing using the 2D modifier are fine, another series of meshes I am displacing unsing the displace slot in the vray material may be the ones that crash vray...
            Having to apply the displ mod is a pain, sometimes, because whe I update the DWG, some (old) elements will have the modifie, some (new) elements will not, althought they will have the same material....
            Is there a way to select all istances of an instanced modifier? that would help...
            I will try 2D displ. and see if I can render...
            thanks all
            Gio
