When I right click now, the vray properties, proxy, and atc...are all gone....I still render fine, but something has happened......Anyone ever have this...
vray properties gone
most likely you resetted your UI to a default one, or loaded some non-vray custom UI. All the VRay commands are available via the customize UI dialogues, so you can either re-add them manually or do a quick re-install. (no need to de-install as the installer auto-de-installs the old one).
Regards,
Thorsten
