So yeah, I sent a file to BB so that I can continue working on another scene.
I have only one machine working on the irr map calcualtion, but it crashed 70% of the way through. After the crash, BB continued on and finished the calc.
I set up the next BB job to render the final frames, and the GI was screwed up, it seemed that the Irr map reset after the crash. Is this supposed to happen?
I had the mode set to Multiframe Incremental, I assumed this was the reason it reset when. I tried it again, it crashed at a differnt point, but this time I set it to incremental add to current, (in hopes that it would reset the irr map before is started). This still didn't work, the first part of the animation was missing the irr map. Since then, I decided to cut the Irr map into 2 differnt parts, so that I can actually get the project done.
I guess what I am trying to ask is: Is this the way it works? I thought vray would write to the irrmap file only after the frame is flag as completed. Why would it reset it if it crashes?
Also, to speed up the time, if using Incremental, can you have more than 1 computer via backburner help render the differnt frames? or does that risk the chance of both (or more) computers trying to write to the same Irr map at the same time?
