I think I broke my sky. When I use the sun/sky under max 9 and v-ray 1.5 final no matter what I do the sky is white. Any ideas? I also noticed it is showing not being used in max's material editor.
Sun/Sky
Sun/Sky
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
Sun/Sky
I used lele's exposure tool, but since then I have merged the model into a new scene and reapplied the sun and camera, but still white.
float is:
1.6
1.7
1.6
RGB is:
255,255,255Bobby Parker
phone: 2188206812
- Windows 11 Pro
sun/sky
A shutter speed of 600 and and ISO of 100 with f-stop of 8 starts to expose the sky, but those numbers are way off.Bobby Parker
phone: 2188206812
- Windows 11 Pro
make sure under global options you use the new model and conform to max's photometric units.
Drop in a default camera, and the sky should be properly exposed by default (bar gamma curves applied).
The exposimeter does nothing to the objects themselves, but change the value of isos or shutter speed as you would by hand, so there is no chance, as remote as it may be, that a fresh, new camera may be altered by it.
LeleLele
emanuele.lecchi@chaos.com
Disclaimer:
Sky
I did ad a new sun/sky and camera, which corrected the issue. I have also noticed on another project that if I play with the sun/sky/cam to much I can get very lost. Last night I was working on a scene and without changing anything but exposure settings I lost my sun being visible when it was check visible. I have found that when I start to get lost it is best to start over.Bobby Parker
phone: 2188206812
- Windows 11 Pro
