vray 1.5 issue (probably user error :s)
  • vray 1.5 issue (probably user error :s)
    hi.
    i've just done a new install of vray 1.5 using viz2008 but the plugins for vrayplan, sun, sky, etc.. aren't loading on startup.
    probably something i've done wrong i should think - been a while since i set a new machine up
    when the going gets weird, the weird turn pro - hunter s. thompson
    In the file plugin.ini in the root folder of 3ds Max, make sure that the line "Additional V-Ray plugins..." is the last one in the directories list.
      thanks vlado.
      ini file was correct.
      unfortunately i think it's a vista issue.
      plugins will load fine when i run viz as administrator...
      f'kin vista! aaaarghhh!!!!
