sun and sky
  • sun and sky
    Hi everybody.
    I have some problem with vray sun and Sky.
    I make some exterior scene using Vray sun and Sky.
    When I render, with classical texture ( with a correct illumination) all is overbright. If y correct the exposure in the physical cam to make it correct, the Sky is too dark. (I use SRGB correction, or some tweak on curves to approach it)
    So to get a correct sky and correct illumination of my materials, I need to make a 0.5 color correction on all my diffuse.
    Is anyone having a solution ? ( sun and / or sky tweak or anything else)
    Thanks.
    __________________________
    Julien Marpault
    Artistic Director
    EDGE
    www.edge-fr.com
    sun/sky
    are you using the latest release. The pre-release had an issue with the sky darkness.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      yes Vray 1.50.00
      Julien Marpault
      Artistic Director
      EDGE
      www.edge-fr.com
        Did you use an old scene for this, or it's a new one from scratch?
          From scratch.
          I had the same problem with Vray RC1 2 and 3
          Julien Marpault
          Artistic Director
          EDGE
          www.edge-fr.com
            and when I use SRGB correction, due to the fact that I use color correction at 0.5 on all my diffuse, the image is desaturated.
            So I don't use SRGB correction for the moment.
            Julien Marpault
            Artistic Director
            EDGE
            www.edge-fr.com
              In that case, if you can post some images, it would be helpful.
                instead of applying post correction, use the script i provided for the ".255 method" thread in the tips and tricks.
                The darker the diffuse, the brighter the sky.
                It's very easy to compensate for a whole set of maps in a complex scene within a second or two.
                Lele
                emanuele.lecchi@chaos.com
                Disclaimer:
                  Thanks
                  Julien Marpault
                  Artistic Director
                  EDGE
                  www.edge-fr.com
                    I just tested your script.
                    It's great !!
                    Thank you very much.
                    Julien Marpault
                    Artistic Director
                    EDGE
                    www.edge-fr.com
