ambient occlusion and physical camera
  • ambient occlusion and physical camera
    Hi all,
    Im using the physical camera and Id like to run and ambient occlusion pass... Now I have about 15 cameras in the scene, there all settup for the lighting/gl of the scene.
    The problem I have is that if I turn off GI/light, add a material with a dirtmap in the diffuse slot, with self illumination at 100%, all the physical cameras render the ambient occlusion very dark (as you would expect because Iv turned all the lights off)..
    Now is there an easy way to fix this...remember I have about 15 cameras all setup up, I dont really want to have to change all of there iso and shutter speeds to make the AO bright....and then change it back again after the AO pass?
    mdi-digital.com
    turn off exposure in the vray camera.
      yep, that worked a treat!!!
      cheers
      mdi-digital.com
