DR light mat problem
  • DR light mat problem
    the slaves don't properly render objects with light vraylightmat in DR mode in 1.5 - you end up getting squares with different light levels.
    they all do it fine if rendering solo under bb though. but put dr on and all of a sudden some are rendering the light coming from the object at different intensities.
    these machines will otherwise render just fine all day without this light type
    WerT
    www.dvstudios.com.au
    I don't have that problem...
    LunarStudio Architectural Renderings
    HDRSource HDR & sIBL Libraries
    Lunarlog - LunarStudio and HDRSource Blog
      Maybe check to make sure your servers all have the same service packs...we had a bizarre issue here with reflections appearing differently because one slave was missing an extension to the productivity pack...
      seems odd that it would go fine through bb though- Is it repeatable with a simple test scene?
      e.
        maybe you're using a map for the light-mat and some machines can't find the texture. check the paths.
        ale
        ____________________________
        www.indivizuals.ch
