Light Leaks - once again
  • Light Leaks - once again
    it seems that vray doesnt like me anymore...this time i got problems with light leaks. i searched the forum but couldnt find a solution. on this job i am using Vray 1.5 RC3, here is a screenshot to illustrate the problem
    http://img212.imageshack.us/my.php?i...htleaksrt8.jpg
    what i tried and what didnt helped to solve the issue:
    * switched from lc to qmc
    * turend of the filtering of the lc
    * used very high irr settings
    * played with the secondary ray bias
    * changed the surfaceID
    the walls have some thickness, there are no gaps between them.
    Olli
    www.short-cuts.de
    It is hard to say what may cause this right away, since yo ualready tried most of the work-arounds; if you can send me just that portion of the scene though, I'll be able to tell you more on how to solve it.
      sweet, thanks, scene is coming in a few minutes.
      www.short-cuts.de
        Have you tried 'Check sample visibility' under the IR advanced options?
          yup, and it looks allright. no light leaks at all. once i unchecked it the light leaks are back. i am starting to think that it has something to do with the model (created by someone else in cinema4d and exported into the 3ds format).
          Olli
          EDIT: oops, i was using the show samples checkbox not the check sample visibilty checkbox, trying it now...
          EDIT2: that seems to fix the problem...thanks !
          www.short-cuts.de
            well...at first it works fine, now i added some more lights and the light leaks are back...any other suggestions ?
            Olli
            www.short-cuts.de
              Are you re-using your IR or generating a new new one each time?
                no, always a new one.
                www.short-cuts.de
                  for the looks of it that geometry is gonna give a huge headache!
                  Nuno de Castro
                  www.ene-digital.com
                  nuno@ene-digital.com
                  00351 917593145
                    yup, i would remodel the whole thing but the client wants the images tomorrow. like i said, its an imported c4d model done by someone else who didnt finished the job right now i remove the spots in ps and it seemsto work quite good, luckily there are ust a few leaks...
                    www.short-cuts.de
                      I'm not sure what else to try at this point, maybe Vlado has some more tips. I know it can be painful working with someone elses poorly built model.
                        then, definetly photoshop will be ur life salvior tonight!
                        and tomorrow, go after the modeler and drop him a sweet "hello"
                        Nuno de Castro
                        www.ene-digital.com
                        00351 917593145
