VRAY rendering all black
  • VRAY rendering all black
    Hi Can anyone shed some light on this?.
    I am rendering a scene with vray and it keeps rendering everything black.
    My vray license is running and all ok. Somtime if I shut max down and start again the problem goes.
    Any ideas???
    Do you get any error messages or warnings in the V-Ray log file? Does it attempt to render at all, but all buckets are black, or it does not start rendering at all?
      It does render but all scene objects are black.
      Ill take a look at the log.
        Try deleting you 3dsmax.ini file. This happened on a couple stations here and that is what fixed it. I could not duplicate the problem but it hasn't happened with 1.5 final.
          I cant even find a 3dsmax.ini file, I have done a couple of searches but nothing
            BLACK VFB
            I have had a simila experience, although it was an issue with the V-Ray's frame buffer. If I zoomed in/out it would go black until I waited a tad and zoomed in/out again. It was a temporary thing for me.
            Bobby Parker
            www.bobby-parker.com
            e-mail: info@bobby-parker.com
            phone: 2188206812
            My current hardware setup:
            • Ryzen 9 5900x CPU
            • 128gb Vengeance RGB Pro RAM
            • NVIDIA GeForce RTX 4090 X2
            • ​Windows 11 Pro
              3dsmax.ini has moved to the easy to find location of
              c:\Documents and Settings\<Your user name>\Local Settings\Application Data\Autodesk\3dsmax\9-64bit\enu\
              Wasn't that easy :P
              Make sure you have your folder options set to view invisble folders and files.
                Don't want to sound stupid but I had similar experience and fought for hours...
                Check your camera and whether it hasn't fall into some mesh.
                Often while adjusting the viewport, the camera gets into some wall or something.
                BTW, is the render-time quick or slow ?
                nikki Candelero
                .:: FREE Your MINDs, LIVE Your IDEAS ::.
                  Ok, we just had this happen on a project. We hid everything, and started unhiding objects 1 at a time until it rendered black again. Turns out we had made a copy of a proxy instead of an instance and it blew up to the size of our scene so everything was inside of it.
                    this also happened to me some time ago! i spent hours trying to figure out what was wrong!
                    Nuno de Castro
                    www.ene-digital.com
                    nuno@ene-digital.com
                    00351 917593145
                      Exactly, the camera fell into mesh geometry.
                      nikki Candelero
                        experienced this once after turning on volume light for a random spot light...
                        turned it off and it was fine.
                        Architecture Drop-out...
                          I can also confirm at times adding volume light will do this. Turning it off for me, also didn't fix the problem. Removing the volume light and then shutting down and restarting max fixed it though.
                            Volume Light..
                            That sounds interesting, I did add a volume light. Ill remove it and see what happens.
                            Thanks everyone.
