3dsmax.exe unkillable!!!
  • 3dsmax.exe unkillable!!!
    Hello there
    I just made a very eyopening discovery which i would like to share. I was having problems with my bionatics stuff. so bionatics sent me a patch that i had to apply into the max plugin folder. in order todo so i had to close max, which i did. BUT it was still running. Still running in the task manager. So ok i am just gonna kill it. NO WAY it just came popping back up within a second. It was driving me nuts. Until i finally came across the following thread. I hope it might help one or 2 people with the same problem.
    http://www.cgarchitect.com/vb/19689-...kground-2.html
    Ingo
    Yep, the vrayspawner will open a copy of 3ds Max to process distributed rendering requests.
    However, I have had orphaned unkillable processes on Win XP 64-bit which are not in any way related to V-Ray... only restarting helped to remove these (Task Manager > Kill Process would not work).
      Thanx Vlado
      I had to unregister the spawner then max disappeared from the task manager.
      Ingo
        In 1.50Final the spawner can run as a service (if you installed it that way) and you would need to stop the service to get rid of it.
        Max 8 SP3
        V-Ray 1.5 SP2
        WinXP SP3
        Dual Xeon 3.4GHz
        2GB RAM
