light cache resolution size and quality disparity
    Well, if the tests this week-end are fine, it should be ready for upload...
      yay!!
        so is this bug fixed now in the SP? or will this come in another SP?
        I have to patch large renders with regions and up till now I have not used light cache for this exact reason, the patch will always look different with different samples.
          This worked fine in the tests that we made here, but I suppose you can just make a quick render and see how it goes.
            Works fine here too.
            Lele
            emanuele.lecchi@chaos.com
            Disclaimer:
            • #21
              interesting, well ill try again now with Sp1 and see. thanks
              • #22
                interesting. how do i delete my post in the new forum?
                • #23
                  You can't delete posts, but you can edit them... if you want a particular post deleted (or have any other forum issues for that matter), click on the Contact Us link at the bottom-right corner of the forum page and write your request into the form; someone will pick it up.
                  • #24
                    Strange, I'm still getting this problem (render region changing lighting).
                    Vray 1.5 SP1
                    Is there a tickbox I should be ticking somewhere?
                    Patrick Macdonald
                    Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
                    • #25
                      could you post a stripped-down scene to test?
                      Lele
                      Disclaimer:
                      • #26
                        was there a resolution to this problem? I have the same issue going on now... pretty much stuck with the slower brute force secondary gi...
                        (I did email Vlado.)
