particles - opacity - alpha errors
Try adding some bitmap filtering to the opacity map.
It sure renders faster without, but this looks like the price you have to pay when up-close and personal with it.
Then again, i may be well wrong.Lele
emanuele.lecchi@chaos.com
Disclaimer:
Ok tried this too, no effect. Whether tiling, nor cropping. I think there is something really wrong, I don´t dare to say...maybe a ... bug ... ? Also possible is that the particles, generated via script, thanks to Pietro Salerno, are somehow wrong, but I am not into scripting...
...any other ideas?
try and upload a part of the scene, somehow crippled so noone could rip it, and someone'll try.
Chill, brother.Lele
Disclaimer:
Omni_Darker is a light with multiplier -0.9
Turning that light off renders a perfect alpha channel.Lele
Disclaimer:
yep. anything below 0.0 multiplier produces the issue (which in this case is only on one side as the light has a definite range).
I wouldn't know if it's a bug or notLele
Disclaimer:
Ok, Lele, the master,
solved the problem. I had on the left side a light with a negative multiplier and this light produced the errors in the alpha channel. I didn´t know this.
Is Vray always producing these effects with negative lights? Anyway, now I´am able to render the scene.
Thanks to all of you, for the support!!!
