Saved animated irrmap slower with no secondary GI
  • Saved animated irrmap slower with no secondary GI
    With traditional irrmaps, there was a nifty trick where if you did say a irrmap + lightcache calculation, and saved the irrmap, then you could render the final pass with only the saved irrmap and no LC. This meant faster renders as the LC data was baked into the saved irrmap solution.
    I've noticed that with the new animated irrmap sequences, this is not the case. Using the same approach will work, but the final render will be incredibly slow if you don't have a secondary bounce solution turned on. Is this because the LC is not baked into the saved irrmap?
    Do you have the "Use light cache for glossy rays" option on? Or the "Treat glossy rays as GI rays" option in any VRayMtl materials set to "Always"?
    Otherwise, except for their time interpolation capabilities, animated irradiance maps should behave exactly like regular irradiance maps.
      That would be it... thanks vlado, that makes perfect sense.
        Actually Vlado, there still is something strange going on.
        Taking just one frame of the animation:
        • Single Frame Mode: 17.5 min[list:3e58b3eec9]Irradience Map
          Light Cache
          Beauty
        Animated Irrmap Mode (0 interp frames): > 3.5 hrs
        • Irrmap prepass mode + LC: 5 min
          Irrmap render mode + LC + Beauty: 3.5 hrs
        [/list:u:3e58b3eec9]
        It doesn't make sense that working from a saved animated irrmap sequence takes so much longer than single frame mode. The irrmap settings are all identical between the different attempts, as are the LC settings. The only thing that changes is whether I work in single frame mode or save to an irrmap sequence.
        What's going on?
          Bizzare... I just did Irrmap Animation Rendering mode again and it blew through the frame in 15min... making the total time almost the same as single frame mode. Although all my tests yesterday were coming out to 3+ hours for the same configuration. I'm getting very confused here and will have to do some more testing.
            Well, it could happen if there is some discrepancy in the scene between the times the irradiance maps were created and the final rendering (e.g. objects added, removed, or some other change).
              Right now I'm doing some test with animated irr mode, and it seems that single frame is 3-4 times faster than precalculated irr in animation mode.
              No changes were made in the scene, I just precalculated IRR in animation (prepass) mode (too bad all dr nodes cannot be used to help here - only main machine is used to calculate irr) and then switched to animation (rendering) mode - 1 frame for interpolation. And as I said - 3-4 times slower than single frame mode....
              Single frame - 26s.
              Animation - 3m19s
              The only thing that is animated in the scene is the sun. Camera is not moving. There are some translucent objects, but I don't think that this is the issue here...
              2 DR nodes + main machine.
              any thoughts?
              edit: my further test show, that it's even 7 and more times slower than single frame mode, even with only one frames being interpolated. I know that animation mode WILL be slower, but why that much?
              the purpose of a ninja is to flip out and kill people.
              the purpose of an architect is to flip out and design for people.
              ________________________
              www.1050.pl / www.kinetik.pl
                Third that. I had the same experience the other day.
                I'll check my scene for the "Use light cache for glossy rays" or the "Treat glossy rays as GI rays" but those settings are defaulted to be unchecked and "Only for GI rays" respectively, correct?
                  In that case, would be best if one of you can send me a scene to vlado@chaosgroup.com for investigation as I have no immediate idea of what might be causing it.
                    I can't release my scene unfortunately. I will scour my scene materials to check for the settings you mentioned above.
                      At this point, the scene is behaving as expected and I can't replicate the problem. I have had it occur on other scenes as well, so I'll dig something up and get it to you vlado. Thanks for paying attention to this.
                        We are having the same problem here. We try with two completely different scenes, and the render times with animation mode are massive when comparing with single frame. We run Max9x64b and Vray1.5.
                          Would it be possible to send me a simplified version of one of those scenes to vray@chaosgroup.com so that I can take a look at what might be wrong?
                            Scene sent to you Vlado
                              Thanks! I will check it out when I get to the office tomorrow.
