Caustics problem
  • Caustics problem
    I have problem with caustics that wont show if i add just one box-plane for environment. All the time i was do this with alpha channel but in this case I want better integrated image with background because lot of trees, leaves in the scene etc.
    Also box is excluded from daylight (vray sun)
    Here is a scene with one box-plane that simulate environment and caustics is no visible:
    Box environment settings:
    Caustics is visible without box-plane environment
    Any suggestion would be appreciated
    Alex
    www.visumporec.com
    This is solved for the service pack, but in the meantime you can use a VRayOverrideMtl material with the base material to be the background, and the other materials - perfectly transparent.
      Doesn't work for me Vlado
      www.visumporec.com
        Worked for me... What does your VRayOverrideMaterial look like?
          VrayOverridemtl:
          Result:
          Would you please tell me what i must now checked & unchecked in object/vray properties?
          Should i now exclude from vray sun or not?
          Thanks Vlado
          www.visumporec.com
            I meant transparent as with an Opacity map, rather than refraction.
              Valdo, I'll send you apart of scene so you can fix that problem, please
              www.visumporec.com
                just get rid of the refraction and put a vraycolor in the opacity slot.
                  Here is the same result with vrayoverridemtl with vraycolor in opacity slots
                  Material settings:
                  Thanks
                  Alex
                  www.visumporec.com
                    You are almost there... now just make the color in the VRayColor texture black instead of white... (remember that white is full opaque, and black is full transparent).
                      Yes, it work now...
                      www.visumporec.com
                        Couldnt you just move the usn inside of the box as well?
                          Nope, the position of the sun does not matter; only its direction. V-Ray will always assume the sun is infinitely far away.
                            Ahhh of course.. doh.
                            Ta
