Backburner Missing dll: vrender90.dlr
  • Backburner Missing dll: vrender90.dlr
    OK,
    So I have tried to run my renders on backburner, all looks OK but I can only render from the manager, it can see the slaves but does not render to them and gives the following error message:-
    2007/10/30 16:19:01 ERR Error message: Missing dll: vrender90.dlr - VRayMatteShadow ; Missing dll: vrender90.dlr - VRayRawTotalLighting ; Missing dll: vrender90.dlr - VRayTotalLighting
    Please someone help!!!
    installed vray on the renderslaves?
      Yes.
      Both slaves have full software install.
        I'd check the plugin.ini
        Eric Boer
        Dev
          Here is the plugin.ini on all three machines :-
          mental ray 3.5 Reference=C:\Program Files\Autodesk\3ds Max 9\help\mr_reference.chm
          Texporter=C:\Program Files\Autodesk\3ds Max 9\help\\Texporter.chm
          [Directories]
          V-Ray main plug-ins=C:\Program Files\Autodesk\3ds Max 9\plugins
          V-Ray additional plug-ins=C:\Program Files\Autodesk\3ds Max 9\plugins\vrayplugins
            Try removing the ;=; at the end
              I am now getting the following message:-
              Task error: Missing dll: vrayphysicalcamera90.dlo - VRayPhysicalCamera
                What does your plugin.ini look like now?
                  I can see no change to the plugin.ini file.
                    Hm, so the ;=; is still at the end?
                      No, there is no change since I removed the ;=;
                        Ok that seems to be working now.
                        Many thanks.
