brighter frames
  • brighter frames
    I'm having a problem that I hope someone can help me solve. Basically half of my rendering machines are rendering a brighter frame than the rest. I'm using a precalculated IR & LC map for them so they all should be identical, but they're not. The machines are all exactly the same as well. I'm guessing it has something to do with the lightcache since we've used this farm for years with IR/QMC without a problem. I also just upgraded them all to 1.5 if that has any bearing on it. Thanks in advance for your help.
    Check your gamma settings on all the machines to make sure they are all setup the same.
    Cheers
    Mike Kennedy
    Two heads are better than one ...
    ....but some head is better than none.....
      http://www.chaosgroup.com/forum/phpB...ic.php?t=21259
      __________________________________
      - moste powerfull Render farm in world -
      RebusFarm --> 1450 nodes ! --> 2.900 CPU !! --> 20.000 cores !!!
      just 2,9 to 1.2 cent per GHZ hour --> www.rebusfarm.net
