Disable Raytracing in the Maxscript Listener
  • Disable Raytracing in the Maxscript Listener
    Hi, I’m trying to disable Raytracing in the Maxscript Listener. The Raytracer tab in the Render Scene Dialogue is no longer accessible with Vray 1.5 and we have some errant materials slowing everything down, which I used to be able to turn off.
    I thought (OK, I was hoping) if I typed:
    raytraceglobalsettings.enable_raytracing = false
    raytracing would turn off, but I get this message:
    -- Unknown property: "enable_raytracing" in RaytraceGlobalSettings
    If I type this though:
    showclass "raytraceglobalsettings.*"
    .enable_raytracing appears in the list. I’m sure I’m making a very basic error, can anyone help me please?
    www.meetup.com/3DLondon
    In the Render Scene dialog, from the two radio buttons in the lower left corner, switch to Active Shade. Now you will get the Raytracer tab, which you can use to change the settings as you wish. Then switch back to the Production renderer.
      Thanks Vlado, I was hoping you could help. I found out you can turn it off through the trackview as well. Is it possible to set the following value:
      trackviewnodes.raytrace_engine_globals.options.ray tracer_enable
      to false somehow in a script I could run before rendering? Two solutions to the problem already I know, but I was just interested. Thanks, Simon
        that's not a value, but a key track.
        Code:
        animate on
        at time 0 (trackviewnodes.raytrace_engine_globals.options.raytracer_enable.value = 0)
        This will set a key with the value 0 at frame 0
        Regards,
        Thorsten
          Cool, thanks Instinct.
