vrlservice autostart?
  • vrlservice autostart?
    I have to start it manually every time Windows starts, because WIBU loads up too slow on my machine.
    Is there a solution for delaying the VRLService autostart so it begins AFTER the WIBU is fully up?
    I've tried to solve it by myself but I do not understand much of this
    http://support.microsoft.com/default...NoWebContent=1
    Excuse me if I'm asking already discussed question.
    Which version of V-Ray are you using? This was a problem in RC3, but is avoided in the 1.5 final version.
      latest Vray version 1.5 and latest WIBU Driver on WinXPx64 . May be I didn't install it properly. I'll try to reinstal both VRLService and WIBU.
      Thanks Vlado.
        I didn't succeed to run VRLService as a service, but shortcut of the VRLService placed in the Startup works fine now. Thanks for the help.
          Kalografik - I had the same kind of problem, vrlservice wouldn't start as a service either. I thought it was just me being stupid or something... .... I manually start it from the shortcut too.
          .:www.mcphersonyachtdesign.com:.
            mcvltd,
            It's seems to me, the problem is some kind of incompatibality with the WinXPx64. Or my system is totaly muddled. I haven't reinstall the Windows lately.
            Stop the registered "VRLService" service manualy and place a shortcut to the VRLService (the black icon) in the Startup. Restart.
            I didn't tryied to remove the VRLService service totally from the registry.
            VRLService service works fine in WinXPx32 and the black icon then is invisible.
            goodluck mcvltd
              Oh dear, maybe I am stupid after all - running on XP 32 here....
                try this
                *upgrade to Vray1.5 with the latest WIBU Driver. (if needed)
                *after the install start "register VRay License Service" from "Start...Programs..ChaosGroup.....Licencing... "
                *go to Control panel>Administrative tools> Services and check if VRLService is running. Start it manualy if not. Start MAX and check if Vray is OK.
                *If it's not OK try to disable manually the service and place a shortcut to VRLservice in the Windows Startup folder.
                *restart to check if the VRLService starts without conflict with WIBU.
                *if not OK again... you have bad day, try tommorow
                Wish you luck again
                  that's more like it!
                    mcvltd,
                    finally I fixed the problem with the VRLService service.
                    The problem on my system was the NVidia hardware firewall.
                    Just open port:30304 for the "vrlservice.exe" at IPaddress: 127.0.0.1 (which is "localhost")
                    read this for more detailed information
                    http://www.chaosgroup.com/forum/phpB...=175400#175400
                      Thanks Kalografik - will look into it.
