I'm having a little problem with displacement at the moment and hope someone here can help.
I am creating a timber slat wall, with the slats every 1200mm. The slats consists of a bottom panel and then a top layer, the top layer having a gap of 50mm showing the timber from the bottom layer. Rather than model this out for each wall I decided to create a displacement map.
However, when I render the image there is a hole to the underside, which ideally should be capped. Anyone know how to solve this problem.
FYI, displacement is 2d Mapping with an amount of 20.
Regards
Thox
Regards
Thox
