Problem installing 1.5.00 SP1
  • Problem installing 1.5.00 SP1
    I have a problem after install the SP1. When i start max 2008 gives me a lot of dll loading errors "failed to initialize". It seems to be a problem with the loading of the vray plugins.
    I tried to uninstall, reboot and install, and the problem persist.
    What i'm doing wrong?
    www.gaell.com
    In the file plugin.ini in the root folder of 3ds Max, make sure that the Additional V-Ray plugins line is the last one in the directory list.
      Wow, faster is imposible, you are the best vlado.
      The problem is fixed, weird issue.
      Thank you.
      www.gaell.com
        well.... that wasn't obvious...
          in my case it is the last one but I still geht the errors
          edit: vista 64 bit, max 2011
