render elements not appearing in list
  • render elements not appearing in list
    Not sure if this is vray related really. I want to start using some render elements in a current job. I assigned a vrayzdepth, but for some reason, it didn't appear in the list. I added another one, but that didn't appear in the list. So I thought "sod it" and gave up.
    However, they are now both appearing in the VFB! Problem is, I have no way of editing/removing them as they are not in the list!
    Has anyone else had this?
    I am using Max8 32bit (on a 64bit system) with all latest updates and Vray 1.5 final (without SP1).
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    Have you tried restarting 3ds Max? I suppose if worse comes to worse, you can remove them with MaxScript commands.
      I've restarted max, restarted my computer. Just not sure why this is happening at all....
      Kind Regards,
      Richard Birket
        OK - I've now established that its because I am using Opengl as my viewport driver - If I change to Direct3D it seems OK! Problem is, Direct3D isn't stable in my dual-screen setup. Great!!
        Kind Regards,
        Richard Birket
          Maybe try merging your scene into a new one?
            Yes - i might give that a go as it hasn't solved the problem!!!!!!
            If I change to D3d and start max, within a fresh scene I can add render elements as normal. If I load my scene, it stops from working. If I then reset the scene, it still doesn't work!
            I hate 3dsmax sometimes.
            Actually, I hate 3dsmax most of the time.
            Kind Regards,
            Richard Birket
              If you can send me that scene to vlado@chaosgroup.com, I might be able to find more about the issue.
