with new vray sp1, where did the raytracer go?
  • with new vray sp1, where did the raytracer go?
    hello everyone, just would like to find out whether anyone knows where did the raytracing global options go in the render rollout...as i need to disable "show messages".....its not present anymore in the new vray render rolout....or should i be looking for it somewhere else?
    big thanks
    teabag studios
    www.teabagstudios.com
    ah found it...had to switch back to max default scenline and turn it of...then switch back to vray
    teabag studios
      You can switch to the Active shade renderer for a moment; you will get the Raytracer tab which you can change as you wish. Then you can switch back to the Production renderer.
        right ...good hint vlado cos when i swith to max rendered i loose all my vray settings
        thanx
        regards
        martin
        teabag studios
