Another displace problem
  • Another displace problem
    I have a simple plataform with a vraymtl 50% gray and a displacement modifier with a tile map.
    I get this splochy image. I've tried with 2d and 3d displacement.
    Only is fixed whe i turn off the "use irradiance map" option of the material, but this slowdown the render a lot.
    What can i do to fix this?
    www.gaell.com
    Hi gagui,
    It could be to do with this:
    http://www.chaosgroup.com/forums/vbu...ad.php?t=32949
    Is your platform is made by adding an extrude modifier to a closed spline? If it is you could try changing your capping from morph to grid.
    Dan
    Dan Brew
      The problem seems to be the "check sample visibility" option in the irr map rollout. If i uncheck this the problem disapear.
      www.gaell.com
