Updating Instances taking a very long time
  • Updating Instances taking a very long time
    I've received a set from a game developer that is taking a very long time updating instances, I've disabled displacement and even replaced all the materials with a single VRay mat with no effect.
    the scene renders super quick with scanline and very quick after vray has updated instances
    in a cut down version of the scene the vray messages dialog gives me 107 render objects 107 render instances, though there are no instances.
    an interesting note is that opening and closing VRay properties takes longer than usual
    it seems to be similar to this post but that didn't help my problem:
    http://www.chaosgroup.com/forums/vbu...ting+instances
    max 9 and Vray 1.5 Sp1
    nope, no one?
      I know this can happen on 64-bit 3ds Max but as of this time I have no idea what is causing it. It seems rather random and not related to anything that V-Ray specifically does.
      Restarting 3ds Max seems to get rid of the issue.
        thanks anyway Vlado, I've never come across this. I've tried it on a couple of machines and they both do the same, neither are 64 though.
        I tried attaching all the object together to see what happens and that helped, so I'm attaching as many as possible together.
        originally when we got the scene all the objects had separate materials(even thought they were the same) but condensing them didn't really help. they also need all their verts welded, so don't know what going on with the game exporter I assume something there was causing the problem.
          I have the same problem, only just noticed this happening in the last coupld of days.
          All my geometry is modeled in max 2008 64bit. When I render, it keeps getting stuck on updating instances. I hide the geom its got stuck on, it just moves to the next one!.
          I do have instanced uvm mapping on the geom. Its a real issue at the moment for us. Very simple scenes taking ages just to start.
          Vlado, any more news on this?
            If you're using displacement you could have too many seperate objects with vraydisp modifiers on.
            If you've got 10 objects with a modifier on each for the same map, merge them all together. going over 10 tends to start causing major issues.
            edit: hm, re-read and it doesnt sound like you have displacement on.
              Ive been getting the same thing with XP Pro64, 3dsmax 2010-64. might switch to 32bit for sh!ts n giggles to see if there is a difference.
              Cheers,
              -dave
              ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
                Try this
                Open fresh new 3ds max
                Import>Merge
                Merge all your scene, go to F10, set up Vray, disable things like Displacement, texture filtering everything basically and just render, then slowly enable it. It might help you.
                If this wont help. U could try to export whole scene to OBJ, then Import back in new 3ds max scene. During exporting/importing time take care to scan over the progress bar. U might see model that takes long to imp/exp which could cause it.
                Good luck let us know how it went
                  Just tried switching to 32bit 3dsmax and there is quite a difference, as in much faster and I dont even see the updating instances :S weird
                  Cheers,
                  -dave
                    Hello,
                    What do you have your dynamic memory limit set as? (In the SETTING tab) if its the default 400mb it might be that...i usually set mine as 3000 or 4000. But you have to have the Ram to do it.
                    -Fizzgig
                      wow what an old thread bump.
                      from 3 year old memory, the only thing i could do was attach as much as possible.
                      if i got that now I would try dynamic memory first as fizzgig said
                      the Pompeii Job I finished last year used a metric assload of objects and I had to use 32bit version (for physx & rayfire) but noticed it handled the scenes a lot better. at the time I thought it was our plug-ins, but now I wonder if it was 64bit max
