VRLicense service problem
  • VRLicense service problem
    Hello people,
    For some reason the license service for vray is not loading automaticly anymore.
    havent change anything and all was working.
    So when i reboot i have to disable the license server.
    then restart it and all is fine.
    When i try i stop the service i get an error a couple of time "128" or something. but i restart the service fine and it's working.
    perhaps any1 has an idea?
    My Homepage : http://www.pixelstudio.nl
    Which V-Ray and OS version is this? Do you get any errors in the Windows Event viewer?
      hey Vlado,
      after checking the eventlog, i saw some errors. not cause by vrlicence but deu others.
      hasp driver
      and NTGDT.sys << ? no idea what this was.
      i removed all links to them form registery and rebooted.
      now those errors are gone and it seems vrlicense i working again.
      my guess will be that i had a conflict with the hasp drivers, but not 100% sure that this was it.
      Anyways it's working again and no more error in the eventlog
        Hmm seems the problem is back again, however now i have no errors in the eventlog, the onlyone from the VRlicense services:
        The description for Event ID ( 0 ) in Source ( VRLService ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: Service started.
        if i stop the service i get error 128, then i can start i again and it works... ??
          Can you show me the exact Event Viewer log (you can email this to vlado@chaosgroup.com)? You can also try to put a shortcut to the license server in your Startup folder, rather than registered as a service, this should work fine.
            I am having basically the same problem once in awhile.
            please post any results or fixes.
            Thanks
            Ingo
              Are you on Windows Vista too?
