MAX 64/32 or vray 64/32 bit DR problem/question
  • MAX 64/32 or vray 64/32 bit DR problem/question
    Hello. I have a problem here. Scene is set and render on 8core server + 4 core slave + 2x dual core slaves, dual core slaves are 32 bit, other is 64 bit, 32bit rendering more white blocks like there is gamma on renders, 64 bit renders just fine. All machines render with textures. so the textures is not a proble. pls help. any TIP
    Andrian
    _____________________________________
    www.fekta.eu
    Portfolio
    CG Talk
    Could it be that your regional settings aren't the same on all your systems?
    If you're using the , as decimal notation, every system should use that. If there are systems using the . as notation you can get colour differences.
    www.artbyarjan.com - Online portfolio (temporarily offline)
    @home:
    / AMD Phenom X4 @ 3.00Ghz / ATI HD 4890 / 8Gb Ram /
    / Vista Ultimate x64 / Max 2010 / Vray 1.5 SP3a Edu /
    @work:
    / Intel Core2Quad Q9450 @ 2.66Ghz /
    Nvidia Quadro FX 3700 / 8Gb Ram /
    / Vista Bussines x64 /
      ohh maby that's the reason. Thay are for shure diferent.
      Andrian
      www.fekta.eu
      Portfolio
      CG Talk
        Can somebody make exponation about NWF (network work flow), my problem is that not all the machines can load the textures, and proxys.
        paths are networking sets, all the textures are in one folder and proxys as well. Main workstation and server render fine thay are 64bit, but all the 32bit machines doesnt.. all the maps are transfered in all the machines too.
        My question is what is the best way to set the paths to proxys and maps, considering DR.
        Andrian
        www.fekta.eu
        Portfolio
        CG Talk
          Originally posted by Fekta.studio View Post
          ...all the maps are transfered in all the machines too.
          This I don't understand...
          You say that all your maps and proxys etc are in one folder on a server? Then why are all the maps transfered to all the machines? As long as they have access to the server you should be okay.
          @home:
          @work:
            no I just try that as well, just to be shure...
            32bit win winxp dont render any texture, server and one of the workstations witch is 64 bit and working on Vista rendering fine.
            Andrian
            www.fekta.eu
            Portfolio
            CG Talk
              Do you submit your jobs through Backburner? Cause then you have to select "Submit as 32 bit job" in order to render it on those systems.
              Click the Advanced button and check the Submit job as: 32 bit radio button.
              See if that works.
              @home:
              @work:
                Hmmm, same exact problem here (32 bit node=no textures)...so far, plenty of tips here that tried and unfortunately failed to fix the problem, might be a network prob for me, not going to re-do the whole network at this time...
                oh, and fyi, I don't bother with BB since it seems to work even less than Vray DR...
                How is your network set up? Mine is just a workgroup with 4 machines, but I'm eventually going to try setting up my server and networking with a domain instead....
                  Network is just one workgroup 10 machines, no BB, only DR, all the textures are on the server. Paths are set, textures are there, all shares are visible trough windows explorer, network is gigabit.
                  Ill try to bring my laptop and see is there will be the same problem. I got Vista 64 and winx 32bit allready installed on it for the test, hope this is not a 32bit max/vray problem.
                  All the textures are in one folder, when i check missing textures in vray render dialog, other machines stops to render at all. I forgot to mention that all the textures are duplicated in the same paths on the server like in my workstation, no textures are on 32bit nodes, just network path is set to the textures in the scene.
                  Vray is installed as follow: server and 32bit nodes got the render + DR, my workstation is with full license + license server.
                  I hope that I'm not messing tings up..
                  Best reggards :
                  Andrian
                  Andrian
                  www.fekta.eu
                  Portfolio
                  CG Talk
                    What happens if you use the "Check for missing maps" option in the System rollout of V-Ray? Does the 32-bit slave report the textures as missing?
                      Sorry to hijack, but yes, in my case (seems identical) it reports them missing.
                        yes Vlado thay does stop rendering and report that maps are missing.
                        Andrian
                        www.fekta.eu
                        Portfolio
                        CG Talk
                          I find that sometimes when you merge files or import something. they have some materials assigned not compatible with VRAY. Sometimes you forget to change the material or something. In material editor click the icon "get from scene" then make sure in the window that comes up you have the check box "incompatible" selected. You'll be amazed at how many strange things comes up here.
                          It usually also say what objects this material is assigned to, however the other day I had 3 different environments maps show up assigned to environment under the incompatible list (incompatible stuff show up as grey in this list). Anyway I looked everywhere in my scene and also under render environment and could not find these maps. The only way to get rid of it was to make a new scene and merge objects from old scene one by one. After all objects got merged into new file there was no trace of those 3 maps. Very strange, but after the merge there were no strange maps anywhere.
                          Also in max under file menu, check in asset tracking that all your bitmaps are using the UNC file method such as: \\servername\maps\bitmap1.jpg instead of F:\maps\bitmap1.jpg. Sometimes things get overlooked.
                          Kind Regards,
                          Morne
                          Kind Regards,
                          Morne
                            All the directories to the maps are in network. Asset manager alt+t can show u all the files used and all the dir to the maps and proxys. As I say workstation that gets the files from server , and the server is 64bit and render fine, all the proxys all the maps are there, 32bit machines can't. And when I check for missing files in render dialog 32bit machines report that there is a missing maps, 64bit dont. I'll try to render with BB.
                            best regards :
                            Andro
                            Andrian
                            www.fekta.eu
                            Portfolio
                            CG Talk
                            • #15
                              Kind Regards,
                              Morne
                              Good tips, I've experienced, tried, tested pretty much the same things, but it was not the fix. Even happens with a new scene and just one bitmap. If I make the map be located on the slave, it renders, but with the wrong/different brightness, as if a light or reflection source is missing. I used to be able to DR fine, but then switched to 1.5 and x64 mixed with 32, and goodbye DR. I think it's something network related with 32 and 64 bit systems, can't pinpoint it.
