convert vray vertical shift to camera correction
  • convert vray vertical shift to camera correction
    there is any way to covert value from v-ray cam to max standard (max min value +500 -500) modifier?
    i'm making a AO pass with mental ray and the good pass with v-ray, but the two images doesn't match
    thank you
    Why are you using MR for an AO pass and not Vray? I mean, if you would ask for this because you're rendering volumetrics with MR I would understand your need, but why are you struggling with camera matching when you can do AO passes in VRay just fine?
    A.
    credit for avatar goes here
      And u can use material override with vray dirt, and tweak the radius. At least i do that. And it works.
      Andrian
      _____________________________________
      www.fekta.eu
      Portfolio
      CG Talk
        i remember that there is a free script which transfers a vray cam to a standard cam...
        probably you can find it at script spot
        pinpan71
          ok i was able to resolve my problem easily, rebooting my pc.
          The vray cam can work correctly whit mental ray.
          thank you to all.
