Vray with Max 9 x64 - CPU usage problem
  • Vray with Max 9 x64 - CPU usage problem
    I have problem with rendering on this "combination": Vray 1.5 SP1 + MAX9 x64 + Win XP x64. CPU usage (while calculating LC and rendering) is about 50-60% (sometimes 70%). I have try to set Dynamic Memory limit to 3-4GB - default geometry: dynamic - then CPU usage was 98-100% but the rendertime (and LC calculating time) was 2x longer than on MAX9 x32 with CPU 100% usage. Can someone help me with this problem ?
    Hardware: 2xIntel Xeon Quad Core - 4gb RAM - WINXP x64
    Mac
    www.pixelmustdie.com
    What would happen if you set the default memory to static, and the memory limit to e. g. 3000?
      Hi Vlado,
      If I set the default memory to static and the memory limit to 3GB - there is the same effect - CPU usage 50-60% I've even try on "clean MAX" / MAX SP1 / MAX SP2.
      Mac
        any other ideas ?
        p.s. I've noticed that when I have LC+IRRMap "combination" with dynamic limit (3Gb) - LC is calculating with 50-60% CPU - IRRMap is calculating with 100% CPU - Rendering about 60-75% CPU (when displacement areas are rendering - CPU usage 100%)
        Mac
          Originally posted by steveiouk View Post
          Just to close this thread and in case anyone is interested.. I got a new board back, 8gig of memory, and a supermicro super server case. I found an article that explained how the snoop feature on some boards (in bios) causes major performance issues. I found this in the bios and turned it off, and hey presto, my xeon system is finally performing how it should...faster than the qx6700...at last
          Thanks for all the advice..
          Bios setting Maybe?
          Eric Boer
          Dev
            thanks for the advice - but it doesn't make a difference Still the same situation. We have Xeons E5420 on Intel Workstation Board Veronia S5000XVN Motherboard.
            p.s. I checked on Dual Core - Vray on Max x64 works fine - 100% CPU usage.
            Mac
