vray on max 9 and 2008
  • vray on max 9 and 2008
    I am having problems installing vray 1.5 sp1 on max9 and 2008 on the same computer. It tells me to first uninstall a previous version and so I lose either max 9 or 2008 install. is there a way?
    /Daniel
    Daniel Westlund
    is it only me then? any idea of how to solv this?
    /Daniel
    Daniel Westlund
      There is a separate installer for 3ds Max 9 and 2008, so you can just try to install the relevant one.
        depending on your system, you might want to make sure both installations are installed in different folders. (For both max, which is logical, and vray)
        Schoonheid vertroebeld de geest
          thanks. I have tried all this with different installers but it still want to uninstall the previous install befor I can install the new one... this is windows vista ultimate 64bit.
          /Daniel
          Daniel Westlund
            I think I solved it. dit it all from scratch, now it works
            thanks/Daniel
            Daniel Westlund
              or not. The files are there and in the right directory but on start up max cant find the additional, vray plug-ins. we sre two here in the office having the same problem.
              /Daniel
              Daniel Westlund
                Is it the same issue as this?
                http://www.chaosgroup.com/forums/vbu...hlight=plugins
                Dan
                Dan Brew
                  thank you Dan. I hope it is cos I know its in the wrong order now. I´l test it on monday!
                  /Daniel
                  Daniel Westlund
                    Thanks. Now it works!
                    /Daniel
                    Daniel Westlund
